It shouldnt..
Just take the battery out and plug it in to the wall.. That way the battery wont heat stuff up.
Originally Posted by litho ![]() Hey guys, I am thinking of getting a acer netbook for $200 from target, and just adding an external 1tb drive to it, and leaving it on 24/7 for most of the year. Do you guys think the netbook would overheat if its on 365 a year ? it would be sitting on a self in my basement usually around 60 degrees in there. Or am i better off spending more money and getting a same specs except desktop like for example the acer ION. regardless i need one that will be able to stay on at least 360 out of 365 a year with out over heating. will be a file server for my home network/vent server. |
Originally Posted by Marma Duke ![]() Sounds annoying to setup, as hard drives would have to be USB I assume, and only 1 if you want to change settings with a keyboard. |
