Networking three Computers
432 3
I have all of the computers connected to a befsr81 linksys router, lets say now I want to have them to I can transfer files from one to another. How does one do this, does this router even support that?
1 - 4 of 4 Posts
Sorry mate but no they dont have to be part of the same workgroup but it is prefferable... Here is the way to transfer a file quickly and easily...
1. Go into the properties of the folder u want to share and enable sharing for that folder, u may also want to select to enable users to change your files but that is up to you.
2. Go into your network connections window and go into the status of "Local Area Connection" and under the Support tab you will see your own IP address, so write it down.
3. Now on the computer u want to transfer the files to, go into my computer and in the address bar insert \\\\IP Address eg. \\\\10.1.1.3 and after a moment the screen will update and show u all the files shared on that computer, it is then up to u to go into the appropriate folders and copy and paste them onto ur other computer...
Btw, this can also be done the other way round, as in sharing a folder on the computer u want to copy the files to and then pasting into the shared folder...
Hope u get my meaning
Just right click on a folder and select "share this folder"
on another PC just open the "My Network Places" should be default on the desk top unless you deleted it...then you have to look on the control panel
Open "computers near me" and you should see all the machines plugged into the router, dbl click the one with the shared folders
I haven't seen a router where you couldn't just share files like this...works the same for printers. I have nice HP laser all-in-one printer...but the software is horrible. It thinks it needs to open this big massive progream that uses tons of memory just to print a page. I have a older comp that does nothing but run the printer...and fold. (like one WU a month...deadline-less)
1 - 4 of 4 Posts
