1 - 20 of 22 Posts
soo I just built this computer because I have become serious about playing CSSource. I dont know much about computers in terms of overclocking but I know how to use my bios. <br />
<br />
Here's my rig : AMD 64 x2 dual core 4200 socket 939<br />
Asus A8V-E SE mother board <br />
Corsair XMS 2 x 1GB 184-Pin DDR SDRAM DDR 400 (PC 3200) <br />
eVGA 256-P2-N553-AX Geforce 7600GT 256MB GDDR3 PCIEx16<br />
74 GB Western Raptor and 250 GB Western Dig Carvaier or w/e<br />
Antec Lanboy Case<br />
<br />
soo my question is how do I overclock this baby to its max potential? I need help from all you smart people out there. just need someone that wants to help me get this baby all the power she can get. thanks for your replies
tell you the truth i have no clue how do i check that out<br />
<br />
because im trying to get the best performance i can for CSSource
<tr>
<div>
Originally Posted by <strong>Str8VengeaNC3</strong>
</div>
<div style="font-style:italic">tell you the truth i have no clue how do i check that out</div>
</td>
</tr>
</table>
</div>Hmm ok, download this program...<br />
<br />
<a href="http://www.cpuid.com/download/cpu-z-137.zip" target="_blank">http://www.cpuid.com/download/cpu-z-137.zip</a><br />
<br />
And go to the SPD tab, from there you can see which slots your rams are using ?<br />
<br />
<br />
Edit : And try to find latest BIOS version for your mobo and flash it, If you know how to do it...
Nice build! Welcome.
Discussion Starter #6
aight i alrdy have cpu z and the ram is in slot one and slot two.....
ok turn off your computer and switch your slot2 ram to slot3<br />
<br />
So you will be using slot1 and slot 3 that means T1, dual channel<br />
<br />
After that read this guide carefully...<br />
<a href="http://www.overclock.net/amd-general/91-ultimate-overclocking-guide.html" target="_blank">http://www.overclock.net/amd-general...ing-guide.html</a>
Discussion Starter #8
ok i did but i also have 2 x 256 mbs in slot two and four also.....dunno the brand name or any of the specs but they are from my sony that i bought a year ago and it was a top of the line vaio and it was pretty good........and is there anychance we can talk on vent and u can walk me through this better and easier if you wanna talk on vent the vent server I am on and mostly always on is vent2.gameservers.com 4254 pw dpg......now how do i flash bios
<tr>
<div>
</div>
<div style="font-style:italic">ok i did but i also have 2 x 256 mbs in slot two and four also.....dunno the brand name or any of the specs but they are from my sony that i bought a year ago and it was a top of the line vaio and it was pretty good........and is there anychance we can talk on vent and u can walk me through this better and easier if you wanna talk on vent the vent server I am on and mostly always on is vent2.gameservers.com 4254 pw dpg......now how do i flash bios</div>
</td>
</tr>
</table>
</div> I don't have a mic sorry but we can talk on msn ([email protected])<br />
<br />
For the rams, i wouldn't use all 4 sticks. I am not familiar with Asus mobos but 2GB is more than enough. Dont use the 2x256MB kit on this rig.
get rid of those 2 x 256 dimms, you dont need them, and its probably slowing performance down depending on cas timings and speed etc<br />
<br />
<br />
Firstly before you overclock you wana do the normal cleaning out, defrag etc.<br />
<br />
Then you wana read this<br />
<br />
The more info you can provide on your memory modules will give us an indication to their potential. The part numbers esp are important.<br />
<br />
Take a read through the overclocking guide and get an understanding of the terminology used and principles.<br />
<br />
Then come back and ask away <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
yeh the model number and revision would be good info to know, we can then find out what kinda chips your ram is running <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
and also if you don't know anything about overclocking, do a few weeks worth of reading. because if you ask us we're going to start talking terms you won't know. so read and find out where everything is located first, then start overclocking.....
<tr>
<div>
Originally Posted by <strong>3xtr3m3</strong>
</div>
<div style="font-style:italic">ok turn off your computer and switch your slot2 ram to slot3<br />
<br />
<br />
<a href="http://www.overclock.net/amd-general/91-ultimate-overclocking-guide.html" target="_blank">http://www.overclock.net/amd-general...ing-guide.html</a></div>
</td>
</tr>
</table>
</div><br />
in cpuz my ram says its in slot 1 and slot 2, but i put my ram into the 1 and 3 slots on the motherboard, well the 2 that matched but they arnt right next to each other.
Discussion Starter #15
ok heres what kinda ram i got <a href="http://www.newegg.com/Product/Product.asp?Item=N82E16820145488.....i" target="_blank">http://www.newegg.com/Product/Produc...20145488.....i</a> was screwing around and i corruped a windows file but i dont have my product code on me right now i just moved outta my house left so this could take a while
Discussion Starter #16
tells me to re install <Windows root>\\system32\\hal.dll *** does that mean
<tr>
<div>
</div>
<div style="font-style:italic">tells me to re install <Windows root>\\system32\\hal.dll *** does that mean</div>
</td>
</tr>
</table>
</div>you messed up and need to reinstall windows and READ how to properly overclock. one thing at a time.<br />
<br />
find out your max FSB, then find out your max proc speeds. THEN combine them.
Discussion Starter #18
sorry i was screwing with my memory not my fsb
Discussion Starter #19
and by the way i have been looking at this stuff for months i know what your talking about im not a computer noob its just the first computer i have built and now im a hardcore gamer and i care about getting the most out of my pc just the first time doing it i learn real fast just tell me what to do
Discussion Starter #20
first of all i have a question about how to flash my bios. i have no clue how to do that can someone please explain that to me thank you.
1 - 20 of 22 Posts
