12700k, EVGA 3090 Hybrid, MSI Pro Z690-A , G.Skill 32GB 3600 CL16, EVGA 1000w T2, Samsung 980Pro SSD
Hi all. I've completed a recent build and wanted to share the results and also ask for some feedback on the setup and cooling configuration. Thanks to all who have provided help in getting to this point!
System Specs:
Here is how I have the cooling configuration set up currently:
As I've noted in another thread, the 3090 cooling is decent except the memory temp. Even if I pull off the tempered glass front and ramp up all the fans to 100% I still see 3090 Mem temps hitting 82c in Time Spy. At reasonable fan curves I'm seeing 88c and worse yet I'm seeing it hit 95c after extended gaming sessions in Halo Infinite. The GPU stays pretty cool itself in the mid 50c range. Other games don't seem to push it this far. I have a mild overclock of +84 core and +200 memory with 105% power target.
As for the CPU temps, in general it seems to be running ok depending on application. My last PC had a 6700k with AIO and temps didn't jump around like this 12700k does. For general gaming/benching, CPU temps max out around below 60k which seems ok. If I run Prime95 Blended tests for 15+ min I see an average temp of around 60 as well but peaks up to as high as 99c (package and some cores). The coolant temp has hit 42c. This even happens if I put all the fans/pumps at 100%. I've used a few different apps to look at temps: iCue software, GPUz, Real Temp, etc. I guess I would have expected better with this H150i Elite LCD cooler, although I know Prime95 is a pretty extreme application. Are my expectations too high or is there perhaps something wrong with this cooler or my setup? Back in the day, I'd have used Prime95 for 24hrs plus to verify OC stability, I'm afraid to run this thing for more than 15 minutes stock.
Bench Scores:
PCMark 10: 8917
Time Spy: 19699
Time Spy Extreme: 9803
Port Royal 13581
SUPERPOSITION 1080 Med: 31828
SUPERPOSITION 8K: 7573
Thanks!
System Specs:
- Corsair iCue 4000x Mid Tower Case
- i7 12700k (still stock, plan to overclock)
- Corsair H150i Elite LCD Cooler
- EVGA RTX 3090 XC3 Ultra Hybrid (I plan to overclock)
- MSI Pro Z690-A DDR LGA 1700
- G.Skill Ripjaws 32GB (2x 16GB) DDR4 3600 CL16 (running X.M.P)
- Samsung SSD 980 Pro 1TB NVMe M.2 SSD
- EVGA SuperNOVA 1000 T2
- 2x WD Black 5TB 7200 RPM Drives
- Creative Sound Blaster Z
Bench Scores:
PCMark 10: 8917
Time Spy: 19699
Port Royal 13581
Thanks!
