1 - 6 of 6 Posts
Phenomenologist
you see under monitor where it says enabled, primary, unsafe? what does unsafe mean? it works fine for me in gaming 24/7, etc. specs for full rig in sig.
Laptop Enthusiast
What program are you using?
Apologies but I'm a tad uncertain as to what it means myself.
If I had to direct you to a place that might get it answered, the NotebookReview forums might be the best place to grab an answer from. ^_^
Phenomenologist
piriform's speccy download. its alright mate, i am not worried about it anyway, everything is working perfect so i am just going to ignore it for now lol
Laptop Enthusiast
If your laptop screen is overclocked, that might be detecting the higher refresh rate... hence the "unsafe" tag...
1 - 6 of 6 Posts
