NEW AMD RIG!! 2.6ghz STABLE!
827 Views 8 Replies 7 Participants Last post by  soloz2
I finaly got my new Rig, SPECS:
AMD 64 3700 San Diego @ 2.6ghz STABLE ON AIR COOLING
eVGA GeForce 6800GT
Maxtor DiamondMax 300GB
Patriot Signature Series 1GB (2 x 512MB)
The only Way I got it to 2.6 is with a Thermaltake Big Typhoon HS/F.
This rig cost me $880 big ones!!!!! It was well worth it.
GO AMD!!!
1 - 9 of 9 Posts
eVGA GeForce 6800GT
GO AMD!!!
Wow that is a pretty solid rig. Its very good for the price. Nice job on the oc!
THX! Artic Silver 5 is the best with overclocking!!!!!
nice, do you know what stepping your cpu is? you should be able to hit higher than 2.6
yea you should definately get higher than 2.6...Im running stock cooling at 2.71 OCCT stable and gaming works great
LOL
Thermaltake Big Typhoon that is one big cooler!
I just picked up the "Cooler Master Hyper 48" and got my winnie 1.8 to 2.6 I would have gotten the Typhoon but it won't fit in my midtower case.
http://valid.x86-secret.com/show_oc?id=74162
Yeah i got my 1.8 to 2.6 on stock so you can forsure go higher
when oc'ing my 3700 Stepping KABQE SH-E4
shoudl i lower my HT to x4, lower memory to 166 mhz
and then raise fsb to about 250? at 11 multiplyer?
storm you'll want to start your own thread so we can help you w/ your oc.
but to get you started... you'll want to lower your ht to 4x and keep your cpu multi at 11x if you raise your htt to 250 that would give you 2.75Ghz. that is what I'm running.
just a note... your cpu will probably do 2.75... but you need to take it there in small steps.
1 - 9 of 9 Posts
