1 - 7 of 7 Posts
Has anyone tried the new Biostar BIOS yet? It's CU51M811, or the CU51M811RH, which is the modded version. You can get both from <a href="http://lejabeach.com/Biostar/6100-939/6100939bios.html" target="_blank">here</a>.
9 Cans of Ravioli
Only major difference is the FBS limit change, and the ablitiy to show a 7950GX2 correctly.
I've been running the non-modded one for about a month now and it works fine.
Discussion Starter #4
Which version of the BIOS would you guys recommend for using the onboard video. I know the site (Rebels Haven) have modded many BIOSes and some of the mods include improving (increased the speed) of the onboard GPU. Do you guys know which ones improved it the most?
If you use one of those, I highly recommend 3rd party chipset cooling, as overclocking that 6100 makes the southbridge quite hot...and its hot enough already.
Discussion Starter #6
I bought a chipset cooler for my southbridge, and I may buy one for my northbridge sometime, so that's not an issue. I just need to know which one improves the onboard the most.
1 - 7 of 7 Posts
