1 - 6 of 6 Posts
Hey all. New here and looking for some advice on a new build. This is it. Any advice or suggestions would be welcome. Just so you know I'm on a limited buget so every dollar counts
Buying Today
AMD 2400+ 45 w Mobile
http://www.newegg.com/app/viewProduc...103-400&depa=1
Thermaltake EXTREME VOLCANO 12
http://www.newegg.com/app/viewProduc...106-035&depa=1
PDP SYSTEMS Memory 184-Pin 512MB DDR PC-3200
http://www.newegg.com/app/ViewProduc...220-018&depa=0
Already have
MOBO-Soyo KT600 Dragon Ultra Platinum
http://www.soyousa.com/products/proddesc.php?id=256
PSU-Themaltake Silent Pure Power 420 w
http://www.newegg.com/app/viewProdu...-153-006&depa=1
DVD/RW Memorex
http://www.memorex.com/html/product...ID=39&opento=11
Video Card-ATI All In WOnder 8500 128MB
Hard Drives WD 120,160
Tell me what you think. 1st time OC , not looking to make top of the line OC but a decent one.
Thanks
Zetachi
looks good, but an upgrade to a 2500m or 2600m will give u alot more performance. also it would be great to get a better vid card
o yeah...those links dont work
Not sure about it not working, but it's a pretty well-known fact that Via chipsets are far from the best when it comes to overclocking. nForce 2 would be a much better option. And if you do go the route of nForce 2, you may want to consider some PC3500 or even PC3700 RAM as it should let you run higher FSB. For the motherboard, I've been impressed with my DFI, and heard a lot of good from others, so I'd recommend a DFI nForce 2 Motherboard for good overclockability.
YiffyGriffy is correct. The Via boards don't overclock very well because they don't have AGP/PCI locks, Nforce boards do. I don't know if a mobile will work on that board either. Just look at my specs, I can tell you about a Via board.
1 - 6 of 6 Posts
