New build for a friend
311 Views 7 Replies 6 Participants Last post by  dudenell
I'm building a new pc for a friend, how does this build look, should I make any changes?
1 - 8 of 8 Posts
I would spend an extra 8 bucks for a x3 720 BE
http://www.newegg.com/Product/Produc...-193-_-Product
I am a big fan of G.SKIL, value and performance in one. Could save A LOT with GSKIL and their DDR3 line up
Cheers
Originally Posted by dudenell
motherboard might be nice
Any recommendations?
Cheers
I'll definitely make the change on the ram, and I'll look into comparing the x3 720 and the x4 630.
Originally Posted by Hickeydog
You can do better with a Corsair PSU. http://www.newegg.com/Product/Produc...82E16817139006.
Agreed, thanks
Originally Posted by itzhoovEr
Whats the budget?
$600
Maybe a case?
The Cooler Master Centurion 590 and Antec 300 are both good options, however, I would suggest the Cooler Master, it is sturdier (thicket steel), has better cable management, and is larger. The Antec 300 is a very cramped case unless you are using very-budget hardware. Also, you may want a CPU cooler, such as the Scythe Mugen 2, which would give you a better chance of unlocking the 4th core on the Phenom II X3 and OCing a bit (the Black Edition CPUs are very easy to OC)
1 - 8 of 8 Posts
