New build help bios wont start
567 Views 14 Replies 5 Participants Last post by  Drivr3g
just put in a gigabyte MA790X-UD4 motherboard with amd phenom II 810, with ati 4870 video card. I power it on and everything lights up fans work CD drive works However i dont get Bios screen!!!! What could be wrong?
1 - 15 of 15 Posts
tried too still nothing, keyboard is lighted up and everything
You dont understand, nothing shows up on my monitor
your BIOS seems to be corrupted did u flash a new BIOS?
did you plug in the 4 pin power connector to the motherboard?
Ever thought of explaining your self better.
Such as when i turn on my computer everything powers up but I don't get a display.
Martyrdom, are you getting any beep codes after the case is powered on? First thing that comes to mind is a grounding issue with the board. This has happened to me way to many times. Remove the board from the case, check all of the standoffs and make sure they are all properly screwed in. You could even try placing the board on a non-static surface (outside the case) to see if it POST's that way. When testing I usually only run the essentials (processor, board, video card and PSU). Disconnect everything else such as hard drives, optical drives, card readers, lights, fans ect.
Double check and make sure the clear cmos jumper is not in the clear position. If you are getting beep codes upon start-up then that is good news. I would then try a different video card to see if you can get a display.
Let us know...by the way congrats on the new build
Good luck
EDIT: Please also add your system specifications to your signature. This information is very helpful to those that may need it. You can do this by going here: http://www.overclock.net/specs.php?do=addsystem
Lol nevermind, i didnt plug in cpu power cord
Martyrdom, easy fix for the win!
Good suggestion Drivr3g +1
Someone's not having a very good day, I didn't mean anything by it. Calm down sir.
Yeah i got SOOO worried.. haha this happened in my last build as well... stupid mistakes!! LOL
1 - 15 of 15 Posts
