1 - 4 of 4 Posts
OCN,
Forgive me if this is the wrong place to post this thread, I had no idea where it belonged.
I've been building a setup with an Extreme6, 3570k, HAF X, Hyper 212 Evo and an XFX 850w. Only one fan is plugged in so far due to a different problem of mine but apart from that, everything is fine. The HDD, Front panel, GPU etc. all starts working when I turn the computer on and hook it up to a monitor. However, everything will spin for about ten second before stopping. After three or four seconds it will stop and the process will start again. All the wile the monitor does not receive any signal.
Any ideas what might be the problem?
Thanks in advance,
Jaidyn
Not New to Overclock.net
Many things would go wrong.
1- Clear CMOS
2- If it didn't boot Try one Ram stick.
3- If it didn't boot. they the other one.
4- if it didn't boot try turning off the pc totally. unplug your psu from the outlet press off and on and off and on again on the back switch and then try again.
if non of these worked. make sure everything is well connected and very well placed. if not comeback for more troubleshooting
Reactions: JaidynM
1 - 4 of 4 Posts
