1 - 20 of 22 Posts
Hello all. I'm looking to put together a new system, I'm tired of dealing with my 3770K and FX 9370 rigs.
I was originally going for the X570 / 5600X combo but I can't find any 5600X's available. So I'm looking into the Z590 / i5 11600KF combo at the moment. I've watched some reviews and what not, but I'm wanting to get some opinions of rear world use etc.
I only need the CPU / Mobo and Ram. It'll be paired with an RTX 2080.
I doubt many have experience with both. In most reviews the 5600x comes out very slightly ahead, but I don't think it's enough that you'd actually notice except maybe in a benchmark. If you have a microcenter near you, try there. I recently picked mine up for $290 and this b550 board for $144
Reactions: Ahnt
A 10850k or 10900 non k with MCE enabled would stomp a fancy 6 core in most workloads and they are actually available below MSRP. Or you can get a 10700k if you don’t mind burning up your CPU with this whole overclocking thing.
The intel 10700K is cheap and fast for an 8-core. Stop looking elsewhere. Just my opinion.
Reactions: Ahnt
Honestly, even a 10700 will do the job. Slam it on a B460M Mortar, remove the power limit and that's it, it should run at 4.6 GHz on all cores. The 2933 MHz RAM speed is not an issue, you won't see a tanglible difference compared to 3200 or even 3600...
Same gaming performance as unlocked i5 and i7s, enough juice for other stuff, low temperatures with anything other than stock cooler, low price...
Not new to Overclock.net
Here's one video that made me choose AMD for my upgrade instead of Intel. Maybe it'll help you make a final decision on one or the other too:
In a nutshell, overall it has superior performance and much lower power consumption. Oh, and check out this beautiful post written as a reply to me by KyadCK:
Ignore the preview text here. I don't know what's going on with this forum's platform, but that's not the correct preview text. Here's a snippet of the beginning of the post:
Its a long complex story, but the TL;DR of it is Intel got complacent and messed up. Hard.
Part one: The Nodes
In the past, intel has always had a Node advantage, always a step or two ahead of all the other foundries. When the rest of the world was on 45nm, intel was on 32nm. When everyone else got 32nm, intel had 22nm.
And then intel got to 14nm. And then they tried to get 10nm, and got a bit over confident with their design. And they failed. For years. Even today 10nm is used only in laptops and servers, where the latest parts from Intel for desktop, the 11000-series, are still stuck on 14nm. Later this year, as in Q4, Intel might get Alder Lake out. On 10nm.
During this time, TSMC, the ones who make AMD's CPUs (among many other things) got 14nm working. And 12nm. And 7nm (~ even with Intel's 10nm, and what your 5800X uses). Later this year, maybe early next year, they will be on 5nm (~ equal to Intel's 7nm).
Intel is not set to have 7nm until 2023.
Intel has lost their lead.
Part two: The Glue
Reactions: Ahnt
10700k is basically as fast as the 5600x in most cases in single core - games etc, but it does have 8 cores not sure that means alot for a few more years. I do have a 5600x golden sample and I can say it's truly fast but to realize a 5600x's full potenial you also need a decent GPU and some low CL 3600 sticks (like CL 14-15).
The Intel 8 Core can be had for less than 300$. Money saved can be funneled to a GPU that are now overly expensive.
I completely agree with that assesement there is no sense in buying a 6c/12t 5600x for the now price of $378.00 when you can get an 8c/16t CPU for much less and be more future proof. Not to mention with a 10700/10700k (non F model) you also get Intel iGPU which -- if your regular GPU fails you can still actually have a working computer in this day and age of chip shortages.
I see a reason. With AMD, it's likely you won't need a new motherboard for the next CPU upgrade.
I completely agree with that assesement there is no sense in bying a 6c/12t 5600x for the now price of $378.00 when you can get an 8c/16t CPU for much less and be more future proof. Not to mention with a 10700/10700k (non F model) you also get Intel iGPU which -- if your regular GPU fails you can still actually have a working computer in this day and age of chip shortages.
Check this 10 cores out.
This is certainly not the case, as AM4 and LGA1200 are both on their last compatible CPU generation with Ryzen 5000 and Rocket Lake respectively.
AM5 however will likely support more processor generations than the next Intel platform.
Senior OCN Member
AMD would like to have a word with you about that last CPU compatible generation claim on AM4
Reactions: TwoCables
My bad, wasn’t keeping up with the news. Good on them.
lol
Oh noes!
Reactions: Ahnt
I have two 5600x 's but one is still sealed in the box for now, I paired the first one with the MSI B550 Mortar at which I bought new in June 2019 so I had the board already to flash , also paired it with a stock Red Dragon RX 570 8Gb just to see if older video cards get's any uplift .
stock cooler from 1600 AB for temp
Discussion Starter · #18 ·
Well, I'm pretty set on the 10700K now, and I do plan on overclocking.
I'm tired of waiting for a 5600X. Plus 8c/16t I could put to use. Mainly gaming but I do some rendering.
This is what I'm running now, so anything is an upgrade lol.
2489342
Good choice. My 10700K did 5.3 out of the box, but they are a mixed bag in terms of silicon quality. There are no bad choices between the 10900K, 10900, 10700K, and 5800X and 5600X.
Reactions: Ahnt
Discussion Starter · #20 ·
This got put on the back burner for awhile but, in the end I decided to go with the 5600X.
My main rig was a 2700K @ 5.2ghz, 32gb (4x8) of ram at 2133 and an RTX 2080.
New rig is a 5600X @ stock for now (boosts to 4.85ghz) and 32gb of ram (2x16) at 4000.
Monster of an upgrade. Super clique but it's a night and day difference. So many options in the BIOS my head is spinning lol.
2514494
1 - 20 of 22 Posts
