1 - 20 of 39 Posts
Ok well my dads friend needs a new system and i need to design it for him. i was thinking an AMD system. he will be mostly using it for programming, gaming, and other stuff thats needs a lot of grunt. now the fun part, money is no issue! go nuts! (moniter not needed)
FX-60
http://www.newegg.com/Product/Produc...82E16819103608
Gigabyte Quad Royal
http://www.newegg.com/Product/Produc...82E16813128318
3 WD 150gb Raptor
http://www.newegg.com/Product/Produc...82E16822136011 or
http://www.newegg.com/Product/Produc...82E16822136012
Creative X-FI E1337
http://www.newegg.com/Product/Produc...82E16829102191
PC Power and Cooling Turbo Cool
http://www.newegg.com/Product/Produc...82E16817703003
Crucial 2gb x4
http://www.newegg.com/Product/Produc...82E16820146576 or
a choice you would like to make
Keyboard = his choise same goes for mouse
case = his choice also but i would recommend one with good air flow
i will not recommend water cooling or phase change because 1 leak and his system is screwed
Windows Xp 64
4 7900gtx or 7900gt
http://www.newegg.com/Product/Produc...82E16814130280
cooling = make some air cooling of your choice
i will edit incase i forget anything
Originally Posted by simon741
FX-60
Gigabyte Quad Royal
3 WD 150gb Raptor
Creative X-FI E1337
Crucial 2gb x4
Windows Xp 64
4 7900gtx or 7900gt
8gb's ram may be overkill.
Originally Posted by garfish
alright then. and with the graphics should i not get them now and wait for some dx10 cards or just get them now.
Vista isn't coming out untill like Q3 or Q4, so DX10 support is still quite a ways off.
Case: Lian-Li Classical Silent PC767 Silver ATX Mid Tower - $230
Motherboard: Asus A8N32-SLI Deluxe 939pin - $224.99
Processor: AMD Athlon 64 FX60 Toldeo 939 Dual Core - $1035
Video Card: XFX GeForce 7900GTX 512MB PCIe x16 - $529
Memory: G.KILL Extreme Series 2GB (2 x 1GB) DDR 500 (PC 4000) - $197
Power Supply: PC Power & Kooling Turbo-Cool 1KW (1000W) PSU - $489.99
Sound Card: Creative Sound Blaster X-Fi Platinum - $185
CPU Heatsink:CD Drives:Fans: Masscool 120mm @ 96CFM - $5.99 (2x if you get the Zalman Heatsink) (3x otherwise) Use these to replace the fans that are included with the case. And if you decide not to get the Zalman, use the third one for the Heatsink.
Accessories: Arctic Silver 5 Thermal Compound (MUST HAVE) - $16.99
Total: ~$3200
8GB its definatley over kill right now.... no more than 4! i mean even 2 is sufficient right now! but if money is no issue get like 4 sticks of some good OCZ Plat.
Discussion Starter · #12 ·
CPU Heatsink:
CD Drives:
Total: ~$3200
i like the sound of this system
I wouldn't wait, it's going to be a while... get this memory
is there much difference between the g.skill and corsair ram
The G.Skill posted is EoL, the new ones are comming out now, but arn't very common.. The Corsair will OC better, plus it looks a lot better.
Figured you would. When I hear Money no issue, i don't think overkill maximum load. I think of what I would get. Even if money wasn't an issue, one 7900GTX would be enough for me.
Discussion Starter · #17 ·
yeah but i think i might still go with SLi and are the XFX cards much different to BFG cards
OG
I'd get an Evga one there cheaper in price,with the same performance.
Definately get 4gigs of ram. It may be overkill but get it. Evga and xfx are good because of there warranties. You really dont need the pre oced ones because you can do that yourself. I would go with xfx or evga. Get Sli also.
Alot of people have the notion that BFG cards are better than XFX, eVGA, etc, becuase they started overclocking their cards first. But XFX and eVGA are taking over the factory overclocked part and doing very well, XFX and eVGA also have better warranties than BFG, there's nothing physically different in any of the cards, other than maybe the visuals the cards are the same...
If you want to go SLi, just get a second 7900GTX, the system will be $~3900 but money isn't a problem so you should be good.
1 - 20 of 39 Posts
