1 - 6 of 6 Posts
After much deliberation I have decided to go Core Duo.<br><br>
I've got the case & GPU as listed in my spec but the rest will go and be replaced by......<br><br>
Core Duo E6600<br>
2GB Corsair XMS2 6400<br>
Asus P5B Deluxe Mobo<br>
Corsair Nautilus 500 & GPU Waterblock<br>
Corsair 620W HX PSU<br><br>
Price and stuff from the following.........<br><br><a href="https://secure.scan.co.uk/Shop/ViewCart.ASP" target="_blank">https://secure.scan.co.uk/Shop/ViewCart.ASP</a><br><br>
Is this is a good setup? I'm new to Core Duo so in a few weeks when I get home and build this puppy I'm gonna need some expert advice on oc'ing it.....thats where you guys come in!<br><br>
Is the Nautilus 500 any good? I've read reviews that love it but do you guys rate it?<br><br>
Alos, is that the best mobo for oc'ing?<br><br>
Cheers
scan might be expensive.. try <a href="http://www.aria.co.uk" target="_blank">www.aria.co.uk</a> and <a href="http://www.overclockers.co.uk" target="_blank">www.overclockers.co.uk</a><br><br>
aria is cheapest usualy<br><br>
yes that a good mobo for ocing, but it dosnt support crossfire , and it uses 965 chipset<br><br>
nautilus is good, i sugest buy chipsets blocks too<br><br>
drop the corsair psu and buy OCZ gamestream 700w for same price
thanks for the links mate, i'll check them out now
Discussion Starter #4
What mobo would you reccomend? The latest and best preferably
I hope you have better luck than me with the Corsair RAM you plan on buying.<br><br>
And yes, I've red that the Nautilus is a decent WC kit. I think someone in this forum has one but can't put my finger on who, but based on the reveiws, I'd say it's a 9 in a scale of 1 to 10.
Discussion Starter #6
What problems did you have with the ram?
1 - 6 of 6 Posts
