1 - 3 of 3 Posts
my name is mike and from north wales and just joined and-well I found my way here, this site is big and very confusing and it is gonna take a while to find my way around I dont even know who I am talking to right now. anyway I decided to update my build of 4/5 years ago. firstly I want to use water cooling and keep my old case which is where I have the problem. I believe there is a silverstone grandia forum here but cant find it. I need to mount the rad. externally and need some expert help. I dont know where I should be =new build -water cooling or -case modifying -silverstone. hope some one can help. have not bought any parts at all yet and i am inlimbo.
Dark and Dropped SUV
Hello, Mike, and welcome.
Guess it's up to you on what you want to do. If you modify your old case with just water it'll be a lot cheaper than doing a whole new system.
Hello mr B I am doing the build anyway but last time I did one I gave up on water for cooler and regretted it after. I always feel the cooler simply blows hot air into the case and as such is very inefficient so I am thinking I could leave the fans on the inside on the side panel, I have two running on there anyway and put a silverstone slim tdo3 on the outside. should work ok, fit wise anyway, but might look a bit untidy, so I was looking to get a shroud or something to cover the rad.to finish it off.
1 - 3 of 3 Posts
