1 - 4 of 4 Posts
I need help figuring out if this is a good rig or not, i'm new to the community and the over all experience of building my own PC from scratch.
COOLER MASTER Silent Pro Gold Series RSA00-80GAD3-US 1000W ATX 12V v2.3 / EPS 12V v2.92 SLI Ready CrossFire Ready 80 PLUS GOLD Certified Modular Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171056
Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
ASUS P8Z77-V DELUXE LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131818
EVGA 02G-P4-2680-KR GeForce GTX 680 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130768
2X G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277
COOLER MASTER V8 RR-UV8-XBU1-GP 120mm Rifle CPU Cooler Intel Core i7 compatible
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103055
COOLER MASTER CM Storm Series Trooper (SGC-5000-KKN1) Black Steel / Plastic ATX Full Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119245
ANY tips or helpful hints would be great.
I'm no expert but that PSU is overkill unless you planning to pick up another 680 to SLI.
Use the money you would save on it to get double the ram (2 x 4gb).
Also for others to help you, please include what you will be using the computer for and your price range. Depending on your needs, you might be able to get away with the Asus Z77-V or V Pro.
And did you mean to leave out a SSD or HDD?
Discussion Starter #4
yeah I meant to leave out the HDD because i already have two that ill be using. and mostly ill be using this for heavy AutoCAD work but i will be using it for gaming as well. the reason i wanted this board was because of the built in Bluetooth feature but then i guess i can just pick up some cheap bluetooth wireless device.
Im already getting 8 GB of ram i dont think ill need to go more than that but then again i might, idk. lol
i thought the PSU was going to be over kill but i didnt know what wattage i needed so i went with a well above what was recomended.
Edit: i knocked it down to a 800 Watt power supply. same type basic, still coolermaster.
COOLER MASTER Silent Pro Gold Series RS800-80GAD3-US 800W ATX 12V v2.3 / EPS 12V v2.92 SLI Ready CrossFire Ready 80 PLUS GOLD Certified Modular Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171057
i think ill go with the ASUS Z77-V PRO and just get a bluetooth dongle.
1 - 4 of 4 Posts
