Hi all,
Last week i finished my new build, these are the parts i used.
Case: Silverstone TJ-07
MB: MSI P67-GD65 (3)
CPU: I7 2600K
Watercooling:
XSPC res/pump 750L pm
XSPC RAD 480 and 240 with push fans
XSPC RASA waterblock
The problem i have is that my temps are higher then my last build on air.
I overclocked my cpy to 4.8 GHZ @ 1.350v in bios
When i run prime 95 or intel burntest (high) the temps are;
core 0 min 27 max 58
core 1 min 24 max64
core 2 min 25 max 67
core 3 min 25 max 63
The strange thing is that CPU-Z is showing 1.424v at max load and True temp 1.3711v at max load ???
Are these normal temps for this build?? I was hoping for much lower temps.
Could it be that my thermal paste is not applied correctly?? I used the line method.
Thanks for the help,
Tammo
CPU: I7 2600K
Watercooling:
core 1 min 24 max64
Tammo
