new build wont post need help please
451 Views 14 Replies 5 Participants Last post by  ObviousNinja
Just put together my sig rig (pics on the way) but it wont post I have a backlit LED keyboard and that is not coming on either if that helps at all the monitor just says no signal. I have tried switching from DVI to HDMI I will try VGA while posting this.
1 - 15 of 15 Posts
VGA does not work either going to try to switch ram position.
Does your mobo LED's lite up?
Boot up with 1 stick of RAM, switch the GPU to a different PCI-E slot. Do the fans turn on? Lights? HD/DVD? Nothing is shorting out the motherboard, correct?
yes the mobo lights up even boots using the onboard switch
changing DIMMs did nothing
The mounting for the CPU was a little unstable I attributed it to shooty craftsmanship maybe a remount?
Originally Posted by boyasaurus
have you plug both power 24 pin and 8 pin?
yeah first thing I checked
Everything is on and connected correctly I just don't see a post from the computer when I boot. Nothing but a blank screen.
Does it have a Post lcd, the thing that has the code on it that tell you what its doing? ( i forgot what it was called
) If it doesn't change at all or doesn't respond to anything like no ram or GPU or CPU or what not,then its probably a dead board
That happened to me with my 780i last month
but just check the cables, reset CMOS, and what not.
keyboard works when I plug it in the front USB ports not the back one that I tried
Originally Posted by Ziox
Is does it have a Post lcd, the thing that has the code on it that tell you what its doing? ( i forgot what it was called
will do
Still nothing what did I do to deserve this.... Asus has just made an unhappy customer. I cable managed this whole board only for it to be dead...
Sorry to hear that
but at least you weren't like me I set up my watercooling system and cable management that took 6 hours of work before i knew mine was dead
It might not be asus's falt, sometimes the slightest amount of static electricity will kill a board but who knows
Sorry to hear that
I was just trying to get the system to post today water cooling is on the way for me. I was grounded with rubber soles the entire build whatever newegg will replace it. Sigh now I have more waiting to do yay...
1 - 15 of 15 Posts
