1 - 11 of 11 Posts
ok so i have im making a new build here are all te things i have
have:
power supply 550W(probably not enough)
memory pqi(2x512mb)
hard drive maxtor 300 gb
case super lan boy including fans
sound card audigy 2 zs platinum
already picked:
memory: pqi TURBO 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit http://www.newegg.com/Product/Produc...82E16820141064
gfx: EVGA 256-P2-N761-AR GeForce 8600GTS 256MB 128-bit GDDR3 PCI Express x16 HDCP Video Card
http://www.newegg.com/Product/Produc...82E16814130084
need to buy:
cpu
mobo
Originally Posted by dani
gfx about 150$
memory 70-90$
cpu about 200$
mobo about 150$
What do you want to do with your system? CPU isn't that important if you plan on gaming, you shouldnt have to spend $200 on it. I'd say if you have ~$600 for gfx, ram, cpu, and mobo, get an 8800GTS and use the rest of the money on all of the other parts.
So:
Video Card: EVGA 8800GTS 320MB - $279
http://www.newegg.com/Product/Produc...82E16814130082
RAM: Same stuff - $89
CPU: 3600+ Brisbane - $63
http://www.newegg.com/Product/Produc...82E16819103046
Mobo: Biostar Tforce 550 - $80
http://www.newegg.com/Product/Produc...82E16813138026
Total: $511
What brand PSU do you have? If it's one of those el cheapo nonames it won't be enough to power an 8800GTS. I left ~$60 just in case you need a PSU.
umm i want an intel
and i want something tht will be a little future proof
and im gonna do gamin and multitasking
Why an Intel? The 3600 Brisbane costs about 1/3 of an E6600, and with a little overclocking it will perform equally or better while gaming. The Brisbane is a dual-core, so you can multitask with it.
is it equal with E6320?
No, not at stock. But the 3600 is a good overclocker, and with some overclocking there will be a negligible difference in games. The video card does all the work, anyways, and the 8800GTS > 8600GTS. Sure, you won't get 10 seconds in SuperPi, but you'll save a load of cash.
1 - 11 of 11 Posts
