new card to replace onboard
437 11
Hey,
I want to buy a new gpu to replace my old onboard card.
The onboard one is a ati radeon xpress200 chip 256mb (yeah he eats my ram).
It's an old system with a socket 939 so i will buy i new system, but until i got a new one i'd like to know which graphics card i should use to replace the onboard.
I don't need exreme graphics but just a card so i can play my old games like counterstrike source and bf2/2142 on higher settings than low
1 - 12 of 12 Posts
Old school
Also fill in your system specs
as above
if possible i say a 9800 GT. yeah, a 9800GT, or an 8800GT. shoot me, but before you do, try it..
or alternatively if the PSU is a low power PSU, a 4670.
Ey,
Okay thanx for the fast replies. The cpu is just a sempron (i think you know that is amd
) on socket 939 oc at 2ghz can't go higher because of locked bios. it got one pci-e 16x lane and 2 free pci's but pci card's are expensive and slower. And i prefer ati. But if you guys say that i can better take a nvidia, that is fine. Ow and i just got 350 watt power suply, but i can buy a new one.
Hey mate,
Since your CPU is a Sempron and the PSU is 350W there's no point in getting a very high end graphics card, you are likely to find more value in something like an ATI 4670 with 512MB. I actually had something weaker with a sempron, I had a 9500GT(8600GT), but I was very disapointed. A 4670 will do good.
The jump from your actual config would be immense without spending a lot, or needing to change the power supply (I'm not sure a 9800GT would be well served by a generic 350W).
Cheers!
...and yes, if you wanna stay on this forum, which we all hope you do, you may want to fill your system specs, under the "User CP" menu up in the middle of the page.
Old school
Yeah, if you get a HD4670 you won't have to buy a new power supply.
Just check http://www.salland.eu
Cheap dutch shop.
Efficiencycionado
+1 with the 4670
Goodbye
1 - 12 of 12 Posts
