1 - 8 of 8 Posts
I was watching this video in my CADD class and they have this gass thats completly transparent that they put in windows so all you need to do is turn on the power to the window and the gas in it will turn into a visible gas taht no one can see threw, is it possible to have it in a computer case almost like inside the walls of a plexy glass case. the reaction is imediat (spelling) <br />
<br />
<br />
my cheap diagram<br />
<br />
<br />
inside comp| gas | outside comp
Yes
I don't think that would be possible unless you have some kind of tubing to keep the gas in. If you want the gas to stay within the computer, you would have to keep the computer air tight, which isnt a very good idea. Or are you talking about a hollow sidepanel with the gas sealed inside the panel? you would need some seriously thin plastic, glass.
<tr>
<div>
Originally Posted by <strong>FaLLeNAn9eL</strong>
</div>
<div style="font-style:italic">I don't think that would be possible unless you have some kind of tubing to keep the gas in. If you want the gas to stay within the computer, you would have to keep the computer air tight, which isnt a very good idea. Or are you talking about a hollow sidepanel with the gas sealed inside the panel? you would need some seriously thin plastic, glass.</div>
</td>
</tr>
</table>
</div>naw i'm talking about somhow making the case have the gas IN it. yeah ur second assumtpion all it needs is electric current .
Yes
wait let me get this straight, would the gas be inside the case where the components are or literally in the panels of the case (in the plexiglass)
Starting to become a BOFH
Something like the glass in Splinter Cell Chaos Theory? <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />
If you wanted, you could make a little champer or thin glass panel on the side thats see thru until the gas comes out but DO NOT put gas in the case itself and make it air tight!
Yes
Im not exactly sure what his idea is but it sounds really cool.
ive seen glass like that in a bathroom before<br />
<br />
it was in florida<br />
<br />
you walked in and if you forgot to flip the switch everyone could see you <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />
1 - 8 of 8 Posts
