After getting my water system in my rig, i have hit a bit of a snag. I was forced to install the pump to the side of the PCI slots, and i thought that it would be fine there....but it turns out that a full sized PCI card - Like my Audigy will not go in the slot with the pump next to it
I have had a good look at my case, and there is nowhere else for the pump to go...so now i have a question...
1. Does anybody now of a card that is as good as the Audigy, but the card itself is not as wide as a standard PCI card.
2. Would i be better getting a bigger case, like this one http://www.compu-square.be/uploaded_..._190x170_2.jpg and if so, do you think my L30 pump would have enough grunt to pump the water up to the top of this case (where i would be putting the rad).
