1 - 10 of 10 Posts
I'm not sure *** I did wrong but after buying a new case today and 600w psu, I put vall my hardware in it and there a constant beeeep after I hit the power button. of course it dont boot up.
I feel like complete idot but this is the first time I've actually swapped everything into a new case.
Any suggestions on what I could have hooked uo wrong?
oh and the case is http://www.bccpc.com/712-4hlw-bk.htm
You may have a short on the mobo, make sure u don't screw it in too tightly. Maybe your ram isn't properly seated in the slots? Theres lots of possiblities.
Try taking everything out of the case, make sure its working and then start over.
i dont think its a short circut as something wolud have fried and the system wouldnt have startted at all .
Did you know that the beeps are for diagnostic purpose if you can tell me how many beeps you get i can tell you were the problem is.
Most probably its ram not being seated probably
You might have wired the system speaker headers wrong. Check your motherboards manual for reference to your motherboards headers.
take it all out and run it table top. maybe you had a stndoff in the wrong place.
make sure you gfx/memory/cpu are all seated properly.
Discussion Starter #6
never took the ram out so thats outta the question. I have a feeling I could have somthing hooked up wrong from front panel to the mobo. hd led,hd active led,pwr switch ect. can that cause this issue?
now the connectors are labeled but they'll fit on either way 180 degrees. should the lables face the f panel or toward the mobo.(back of pc)?
Discussion Starter #7
found out what my issue was. well because my ne case has fan controls for the cpu and temp censors for the fron display. well I hook up my fan for the cpu to the case's front control panel like it said to do but I now need to go into bios and disable the warning alarm for my cpu fan....lol oh well live and learn
There should be a dedicated port for the CPU fan!
yea use the dedicated one on the mobo.
Discussion Starter #10
well my cpu fan run great pluged into the fan and temp control. i just had to go into bios and disable fan failure warnings.
now all is running great.
1 - 10 of 10 Posts
