1 - 13 of 13 Posts
Lian-Li's are one of the best they are good, but if you want room get a server or full tower case.....make sure its alluminum or steel.... better cooling that way...
Well Budget play a part in this? Well, if your gonna build a really good system and oc it, you need a very good case. I'm not great at this stuff, but heres an ok one...
http://www.newegg.com/Product/Produc...82E16811233003
That case should have a nice airflow, and easy opening and lots of space too.
That was going to be the next case I recommended
http://www.newegg.com/Product/Produc...82E16811146018
http://www.newegg.com/Product/Produc...82E16811129154
Those also are very nice
Originally Posted by myComputerSucksMore()
Is ebay a good place to buy, i already have an account there.
Yea its not the best place, depending on the seller....go for it, prolly get it cheaper there
I guess, but stuff has happened before where they say its new, stuff it in some box, and the case is scratched. If you REALLY trust the buyer, i guess, but you can get very decent cases off of newegg for about the same price as ebay.
Thermaltake Armor all the way. Best case I've ever owned.
Well honestly you need a budget and a purpose.
If you plan on moving your computer around alot, lans and whatnot, lian li is excellent as it is all aluminum. Frozencpu.com even offers some modded Lians for a price...
If your comp is going to be sitting in one spot, and you plan on overclocking get pretty much anything made of steel with a Side Port over the CPU. This will drop temps by LOADS and will only requre a decent heatsink fan (use a fan controller) and your comp can be near silent.
The rosewill listed in my specs is excellent in cooling, honestly best 50$ish ever spent on my comp. I have 1 exhaust fan , and a heatsink fan,...and thats it and my temps are low.
So spend according to taste, budget, and purpose.
What specs should i look for in a good case to buy? I am lokking at building a new computer. Tell me what is overkill. Any help is much appreciated.
http://www.newegg.com/Product/Produc...82E16811119039
COOLER MASTER CM Stacker STC-T01-UWK Black/Silver Front panel with Black side panels Aluminum/Steel ATX Full Tower Computer Case - Retail
http://www.newegg.com/Product/Produc...82E16811119068
COOLER MASTER Centurion 5 CAC-T05-UW Black Aluminum Bezel, SECC Chassis ATX Mid Tower Computer Case - Retail
also with window
http://www.newegg.com/Product/Produc...82E16811119077
http://www.newegg.com/Product/Produc...82E16811108290
IN WIN X710 Black Steel ATX Full Tower Computer Case 430W, ATX 12V Power Supply - Retail
1 - 13 of 13 Posts
