1 - 13 of 13 Posts
I curently have <a href="http://www.kohryu.com/picture/cmaster/20040429/Centurion5.png" target="_blank">this</a> case, and intel stock fan.The case as a 80mm CM intake fan, and a 120mm CM exhaust fan.<br />
When i firts get the pc , the intel stock fan was always running at 4000rpm (and doing like 500db) but i fixed that i runs now at 1600rpm(still very loud).<br />
So my question is , wich fans (cpu+intake+exhaust) would make my computer fresher and less loud.<br />
I was thinking of using a Tuniq Tower 120 with no fan, would that increasce alot my temps?<br />
They currently are:<br />
CPU:30 idle;36 load<br />
Mobo: 42 idle; 44 load<br />
GPU: 65 idle; 80 load.<br />
Thanks<br />
PS: try to keep a good price/performance ratio, ok?
Administrator
Well to match your specs for cooling and for your Needs i would reccomend the following. <br />
<br />
Thermaltake Big Typhoon :<a href="http://www.overclockers.co.uk/acatalog/Thermaltake_CPU_Coolers.html" target="_blank">http://www.overclockers.co.uk/acatal...U_Coolers.html</a><br />
<br />
Tuniq tower : <a href="http://www.overclockers.co.uk/acatalog/Other_CPU_Coolers.html" target="_blank">http://www.overclockers.co.uk/acatal...U_Coolers.html</a>
Would I be able to use the Tuniq without fan?<br />
Waht about case fans?<br />
I heard silverstone wore good ones....
<tr>
<div>
Originally Posted by <strong>[email protected]</strong>
<a href="showthread.php?s=f0ff622456a527c34b14aeab359ee59d&p=1393539#post1393539" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">Would I be able to use the Tuniq without fan?<br />
I heard silverstone wore good ones....</div>
</td>
</tr>
</table>
</div>You are able to use any heatsink without fan, I just can't promise it will work 7 hours later <img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick Out Tongue" class="inlineimg" /><br />
<br />
Silverstone fans are great though.
Administrator
Yes you can run that heatsink without the FAN however its cooling ability will drop so i would keep it mate. <br />
<br />
Yes Silverstone fans are great. <br />
<br />
However make sure you have good case airflow also.
Discussion Starter #6
Well, what woukd be +/- the cpu temp without a fan?<br />
Are they also silent?<br />
I would like to have a 0db pc.....
Well 0db will never happen as you will hear the PSU going or an HDD. I suggest looking at a Arctic Freezer 7 Pro. The fan is silent on the HS, but pushes enough air over the fins to keep it cool. Here in the states one can be had for $20 shipped.<br><br>
pink
Discussion Starter #8
Will the tuniq fit here:<br><a href="http://assets.overclock.net.s3.amazonaws.com/c/c1/c18cf647_vbattach34550.jpeg"><img src="http://www.overclock.net/image/id/616031/width/525/height/525/flags/LL"></a><br><a href="http://assets.overclock.net.s3.amazonaws.com/4/41/41feadc3_vbattach34551.jpeg"><img src="http://www.overclock.net/image/id/616030/width/525/height/525/flags/LL"></a>
I think its gonna be a tight fit, as your CPU sits pretty high to the PSU. Got to Tuniq's website as they have its measurements. And it will tell you the minimum specs of a case needed.<br />
<br />
pink
Discussion Starter #10
Well, this is getting kinda complicated....<br>
I've read in some reviews that Thermalteke big Thyphoon is more silent than the TT.<br>
What's the Difrence between the TT BT and the TT BT VX?<br>
I'm also thinking of using As5 , is it conductive?
Discussion Starter #11
?bump?<br>
i have also have now an exhaust fan under the vga, the mb temp dropped a bit.
AS5 isn't conductive, although it is slightly capacitive.<br />
<br />
But you have to use such a miniscule amount, it shouldnt get on anything other than the CPU.<br />
<br />
My CPU is quite high on my mobo like yours, and i was able to get a TT BT typhoon in the space without any trouble.
Theres no point using a Tuniq Tower without a the fan, the stock fan is near silent at high speed anyway <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" /><br />
<br />
<a href="http://www.tuniq.com.tw/Cooler%20Info/Tower-120.htm" target="_blank">http://www.tuniq.com.tw/Cooler%20Info/Tower-120.htm</a><br />
<br />
Thats the Linky to the Tuniq website. Scroll down a smidge and you'll see the case measurements
1 - 13 of 13 Posts
