Originally Posted by ENTERPRISE1701
WOW u have me very interested...What temps did you get as in i really need good temps lol
I used to get 55°C full load at 3GHz. It is, however, difficult to compare temps from my Prescott with what you currently get with your Northwood. The pressy (in skt.478) runs so hot compared to other CPUs... Also, I only used a 36CFM fan on the XP90 when I was using it, as I found the "Silent" Cat was still too noisy for me...
If you check out
this review of
your fan though, you can see how it can keep
my CPU down to 47°C full load on a HS without any heat-pipes! The XP90 has 4 heat-pipes and a nickel plated solid copper base. With your fan on the XP90, cooling your Northy, I'm sure you would get the kind of cooling you're after.
I would be willing to drop the price down to £20.00 (for the cooler and shipping together) if I leave the "Silent" Cat fan out of the deal. I don't think you'll be needing it anyway, as your fan seems far superior and will most definitely give you better cooling than the Cat can. What'cha think? Any good to you?
Highly-Annoyed
