1 - 6 of 6 Posts
Ok the rig im running right now is actualy pretty fast and runs very nice, and so my brothers offered to get me a new one and hes gna take my one....Now i was looking to get the amd 64 4000, and i found this place that does it for 200 pounds, how does this cpu overclock...or shall i get a opteron for a similar price???..i just wanted to know what advantage do the optys have over the 4000 and max i want to spend is 200 on the cpu..thanks
I would go with the athlon 3700+ (San diego core) and save the rest for another upgrade. The steppings that are being produced are giving amazing overclocking results. Many are getting 3.0ghz+ on air! The only real benefit you'll get with the 4000 is just the extra 12X multi.
Originally Posted by erauman
I would go with the athlon 3700+ (San diego core). The steppings that are being produced are giving amazing overclocking results. Many are getting 3.0ghz+ on air! The only real benefit you'll get with the 4000 is just the extra 12X multi.
I totally agree not that I am totally biased towards the 3700+ sandy cause I own one but I heard many other good things about it, I got mine from newegg.com and I got an E4 stepping which is really good. Also remember that the 3700+ has the same core as the FX-57. as for opteron I would have bought it but when overclocking and the warranty only covers it for servers (not pc's) that can make you change your mind pretty quickly
hmmmm...now that seems to have changed my mind now...mayb a 3700 sd core would be better...i mean 3.0ghz on air..that sounds cool....but is that 100% stable??
honestly I havent tried it at 3.0 but I know I can easily get 250x11 (2750) and HTT is 4x soo my HTT is running at 1000 (anything over is not good - under is alright) and right now I am running it at 24/7. idle is 34 and load is 41. I have the E4 stepping so I know my processor can handle up 70C but for the meantime I am happy.
ps those temps are low cause I have the big typhoon.
Discussion Starter · #6 ·
Yea i noticed the tt Big typhoon...but yea those temps are pretty cool man..i think uve changed my mind to 3700...THank u man
1 - 6 of 6 Posts
