As the title says... I have a Vantec Aeroflow FX120 and it's slightly too long (wide?) for my case.
http://www.frostytech.com/articlevie...id=2327&page=2
Can I cut the ends off the pipes? Are they simply hollow copper pipes? Will it have any noticable effect of the efficiency.
I guess another option is to cut six holes in the perspex side of the case for the ends of the pipe to push through. This might be a problem though as the side of the case slides into position.
So, hacksaw... yes or no?
Thanks a lot
Thanks a lot
