1 - 6 of 6 Posts
I was thinking of getting the dfi sli dr expert and an opty 144 but would it be worth the upgrade to 939 From my current sig rig. Or should i wait a lil while longer for a vcore vmod for my current S754 board, maybe get a second 7600gt now and a new water pump. But if the permonce really aint gonna be much better then ill stick with my rig<br />
<br />
Her is whats in my cart so far<br />
<a href="http://www.newegg.com/Product/Product.asp?item=N82E16813136166" target="_blank">http://www.newegg.com/Product/Produc...82E16813136166</a><br />
<a href="http://www.newegg.com/Product/Product.asp?item=N82E16819103600" target="_blank">http://www.newegg.com/Product/Produc...82E16819103600</a><br />
<a href="http://www.newegg.com/Product/Product.asp?item=N82E16835108063" target="_blank">http://www.newegg.com/Product/Produc...82E16835108063</a><br />
<br />
BTW here is my current water pump...It was a freebie when my other one crapped out <a href="http://www.go2marine.com/product.do?no=93250F" target="_blank">http://www.go2marine.com/product.do?no=93250F</a><br />
<br />
Detailed system specs are as follows::<br />
AMD 64 DTR 3700+ @2604 217 x 12<br />
Epox 8npa sli s754 wont go over 1.6 vcore<img src="/images/smilies/mad.gif" border="0" alt="" title="Mad" class="inlineimg" /> <br />
2x512 mushkin 991433 @217 2.5-3-3-5 will go to ddr500+ with 3-4-4-10<br />
3dfuzion 7600gt pciE 585/750<br />
AOC 17"CRT1280X1024...like a widscreen lcd but not enuff moola<br />
maxtor HDD sata 16 mb cache<br />
winfast tv2000 xp tv tuner so i can play my nes<br />
benq dvd burner <br />
water setup with DD tdx universal amd block/black ice extreme 120mm single<br />
Generic OKIA 600 watt psu<br />
7X80 mm fans and 2X120 mm fans<br />
win xp pro up to date <br />
<br />
If you have any opinions on what to upgrade please tell me.. help me spend my money Thanks in advanced
All ready know that but thank you for the reminder
It'll be an improvement but not much of one. Stick with what you have for now and save up for your next build.
Discussion Starter #5
well if i try to save this extra money im sure it would get spent on bills or the kids so i am going to waste it on my current rig i dont want to upgrade to a new system untill ddr3 is mainsteam so its gonna be a while
Discussion Starter #6
well i decided to go ahead and get a second 7600gt for sli and gonna wait as long as possible for a complete new setup... Give it enough time for dx 10,vista and dual cores to be utilized...... would like to compare the s754 sli to a 939 sli w/7600gt and a 3700 just to see how much of a difference ther really is
1 - 6 of 6 Posts
