HI, There I'am new to AMD and trying to get the best out of my system in terms of performance I have a question I'm using a Crucial Ballistix 3600 CL16 if I let it on auto It can do 1900/3800 16-18-18-18-38 (with just basic DOCP) I wanted to mess with tightening other stuff in the BIOS so I downloaded Typhoon and DRamCalc I export the report from Typhoon load it in DRamCalc fill out everything and no matter what frequency I set as long as I set Micron-B die which it is all I get is not supported if I set it to Samsung-B die it works otherwise it won't is there a solution for this or should/can I use a different die type???
