1 - 12 of 12 Posts
ROG Cpuz reads..
http://valid.canardpc.com/show_oc.php?id=2213195
6 cores? 8130? 4.2G x21..
task manager shows 6 cores, all cores on in the BIOS
It reads fine in the post.
The BIOS is set to default settings.
HWMonitor doesnt show the cores..? or the wattage
Core temp reads 3.9G
My WEI dropped
What is going on?
This is the first upgrade that downgraded and confused my puter!!!
I have the latest BIOS update.
Someone please offer some insight!!
It boots slower.
This replaced my 1055T @ 3.9G Prime95 stable, running great for months. 7.6 WEI, lowest score was the CPU.
CPUz link says this:
This ID is valid, but not published
The ASUS M4A77TD does not list any FX series processors as supported.
Originally Posted by brewermoe View Post
YA seems that way!! But its a Crosshair V formula!
I reset the RTC as well
well you coulda mentioned that before lol.
clear CMOS?
Theres your problem, same thing happened when i swapped my windows install to a new mobo, from core 2 duo to phenom II x4. It couldn't find the other 2 cores no matter what I did, until I did a windows repair so that it fully embraced the new hardware.
1 - 12 of 12 Posts
