I was running cod blops 2 at 15 fps.... Spec Nvidia 760 evga, 8 gbs ram, core i7 4770k HELP PLEASE
I believe that would be the problem then
Ha! Didn't even think of mentioning this. Guess it just seems like common sense when you've been working with PCs for a while... would be an easy beginner mistake though
Well once upon a time there were only like one output for the monitor - so for people new at the "market" it can be confusing with all the outputs in the back
With the igpus I'm pretty sure it does, graphics card goes into a power saving mode and is used for compute tasks (that would be an example usage).Originally Posted by KenLautner
PC doesn't usually turns on if you put the vga / dvi cable in the motherboard with graphic card installed.
Post the link of where you bought it from if you bought it online. Post a screenshot of My Computer > Properties.
From the looks of it, if your 760 is staying at 30C, seems like it's being used so check if thats the case.
Really depends on operating system and motherboardOriginally Posted by KenLautner
