Hi guys,
Looking forward to build an haswell i7 based system. on a bit budget but can be extended just suggest me some good parts also gonna buy these in India.Below is what i am aiming for.
i7 4770k
good motherboard with oc capabilities want something from gigabyte lineup no sli/crossfire required will take one monster gpu(have hd-6970)
16gb rams with good oc potential
250gb ssd
Fulltower cabinet with good airflow for hdd and gpu and capable to mount 120mm*3 fan radiator( need advise if i can run both cpu and gpu on this loop)
Watercooling product suggestions..i can create another thread for this if required
If you have suggestions for another lower end processor type with more bang for buck then ur welcome. Budget right now is about 600$-800$ for cpu,motherboard & aircooling as will study watercooling before jumping into it... Also need to know if my current Noctua cooler has a bracket to work with the 1150 socket ? means is it available to buy somewhere ?
i7 4770k
250gb ssd
