Would help if you gave some information such as what you'll be using this computer for (HTPC? Secondary rig? Primary PC replacement?), and some minor details such as if you'll be overclocking, if you also need a DVD burner (I'm guessing you do, since you listed what you don't need), and if you want an aftermarket heatsink or not. With not much to go on other than you have a motherboard picked out, and don't need a case/hdd/sound card, I'll throw out some suggestions (subject to change if/when you give more information).
CPU:
Intel Core i7 875K
RAM:
Mushkin Redline 2x2GB DDR3-1600
PSU:
Corsair HX750 750W modular psu
Video Card:
XFX HD 5870
Cooler:
Corsair H50 <-- (Can be gotten cheaper)
DVD Burner:
Lite-On iHAS124-04
Hope this helps as a beginning list.
