My friend just purchased the system I was going to get before i decided to keep my P4 chip. Specs to follow..
The problem is that if he goes and plays a game or runs a 3d bench mark at all his computer just turns off..
Specs include
AMD 64 mobile 62watt 3400+
DFI Lanparty UT NF3 250Gb
Ultra X-Connect 500w PSU
Geforce4 TI4600 128mb
DDR400 memory
Thermaltake Tower 112 (4lb copper) heatsink (could this be a problem? if it wasnt on quite right?)
We havent overclocked this at all (currently) we tried once and it was fine was running counter strike online for about 12 hrs lol.. then he got it home and tried to play a different game and it crashed.. ( i think it was the Sims 2 or something) by crashed i mean that after a few min (about 5) in the game it just turns off. It was fine the entire time he was at my house for my lan party then after he gets it home it starts crashing we litterally played Counter Stirke and Counter Stirke : Source for about 12hrs. When he first put the mobo and cpu in his machine he was useing his OLD PSU it was doing the exact samething then.. i figured it was beacuse it was only a 350watt and didnt have enough power. Another odd thing i tested that PSO (the 350w) and it seems to be completely dead now wont power on at all.. dont know if this is realated.
I think he tried 1 or 2 differant bios (both were flashed from windows i belive if that matters). The 2nd time was with a BIOS that was said to be for the DTR mobile 64 chips (this chip as far as I understand is not a mobile but a "true mobile" the 62watt version) when he flashed this bios it said something about not being able to update the DMI block i think.
The only think i can think of is that the CPU heatsink moved when he took it in his car from my house to his ( the matter in which this heatsink is attatched to the mobo (per the instructions) doesnt seem stable enough to me like it could slide up and down the length of the mobo). could that have something to do with it?
Does he need a special BIOS to run that chip in that board? I cant imagine the PSU could be the problem seeing as he has the same as I and it powers my P4 3.4ghz just fine.
I am at a complete loss here and I feel horrible beacuse he went and bought these part at my advice (which was do to all of the help I got here
Thank you all!) And the #%$2 think wont work lol.
His temp are below 40 at Idle, another weird thing is that with every bios we have put in it autodecteded the CPU at 800mhz or so...
Could it be a voltage problem? what should this chip be running at?
Thanks for your help Sorry this is so long just wanted to get all the information i have in there. I'll add more if needed as we attempt to further troubleshoot.
Thanks
-Snow (and his friend )
*UPDATE* he just put i a new BIOS and now windows is listing this....
"Mobile AMD Athlon(tm)64
Processor 3400+
803mhz 512mb of Ram
Physical Address Extension"
When you right click my computer and hit properties. the 3400+ definetly isnt 800mhz lol
looks like this..
Specs include
DDR400 memory
Thanks
Processor 3400+
803mhz 512mb of Ram
looks like this..
