so I used it for about 1 hour and it worked perfectly well and enjoyed using it.
but now the screen has little vertical lines going down all the screen??? some sections are split up like where the black lines are more intense than other areas???
^^ this. usually if there are lines in the screen especially black ones the CFC cables are torn or messed up. this is just from my personal experience. usually this dosent happen unless you open the monitor and flex the cables, but who knows.
My vid card has 2 video outs, I have 2 monitors. Recently my 2nd monitor starting acting weirs, lots of artifacting and pixelization. I switched the cables to the other video out, and it went away.
you aren't using an hdmi switch or nothing to test, right? connect directly
then like other person said, if it's doing it on pc and ps3, i'd say it's the monitor
Is the monitor 1920x1080? And are you running at that? The whole '1080p' thing is just a marketing gimmick. (strong opinion of some people, including myself) It is not a 1920x1200? Just double checking!
Overclock.net
