1 - 4 of 4 Posts
Ive been thinking about getting a new motherboard for a while and have no idea what to get.I made the mistake of getting a prebuilt so i cant oc,with a pretty bad graphics chip so i cant play to many games.I cant buy with a credit card so i can only choose store bought motherboards so i have very few to choose from.Could you please post ideas for a new mobo i should get.Thanks.
Are we talking a mobo for the computer shown in your system specs? If so, its an LGA775 socket. I'd go to Newegg.com (or a place like it) and look at LGA775 socket mobos (look for the ones with good reviews <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" /> ). Personally, I've had good luck with this ASUS P5B - Deluxe (which i *think* should work with your Celeron D).<br />
<br />
You did say that you bought a pre-built rig... who did you buy from? If it was from Dell (or any other pre-built company I suppose) you might run into issues when you try to fit an after market mobo into the stock case.. just a warning.
ASUS P5WD2-Premium for $60 <a href="http://www.overclock.net/sale/123737-sale-sladesurfers-mega-sale.html" target="_blank">http://www.overclock.net/sale/123737...mega-sale.html</a>, could easily overclock that 3.20ghz Celly to 4.80ghz easy. <br />
<br />
You could buy an MO and buy the motherboard from sladesurfer. <br />
<br />
BTW, I used to have a Celeron D 336 which I overclocked to 4.21ghz easy with a P5WD2-Premium board, here look: <a href="http://valid.x86-secret.com/show_oc?id=99474" target="_blank">http://valid.x86-secret.com/show_oc?id=99474</a><br />
<br />
<br />
You have a Celeron Cedar Mill, so most likely you'll achive a (200x24) 4.80ghz easy and since that Cedar Mill CPUs overclock a lot higher than Prescotts, I'm sure you could get over 5.0ghz. <br />
<br />
Buy the board, you will not be disappointed.
Discussion Starter #4
Thanks ill see when that mobo comes in stock at a local electronics store.I cant order online because i cant use a credit card but thanks anyway. EDIT:I have a emachines w3502.Does the ASUS P5WD2-Premium accept ddr 3200.
1 - 4 of 4 Posts
