Help. I just got a new Opty 165 from new egg and installed it this evening. After installing it (using included heat sink and included thermal interface material), I began testing it with Orthos (Prime95). Kept getting the following error message:
FATAL ERROR: Rounding was 0.4737776499, expected less than 0.4
Hardware failure detected, consult stress.txt file.
Torture Test ran 3 minutes 40 seconds - 1 errors, 0 warnings.
Execution halted.
Sometimes the test would run for a few minutes, and sometimes the test would run for an hour or so, but in each instance, the result would be the same. Each time, it was Core 0 that was reporting the error. Core 1 has yet to fail on Orthos.
This processor is a replacement for another new opty 165 that was having similar problems, but in that instance, Core 1 was failing, while Core 0 was not reporting any problems.
Does this mean that my opty is bad and needs to be returned and exchanged (again) or am I doing something wrong, or is there something else that I should look at before I do another RMA?
Execution halted.
