1 - 20 of 59 Posts
The system specs show the setup...Installing windows now...yay... can't wait to start my oc on this cpu...wish me luck!!!
what stepping did you get man?<br />
<br />
It's all about the stepping of the 165 man...If you got a CCBWE, you'll probably only make it to 2.4-2.6, if it's a CCBBE or CCB1E, you have a very good shot at 3.0ghz
I paid extra on e-bay for a ccbbe 0610 but not too much 173.00 retail box better than luck of the draw at the egg!!!
<tr>
<div>
Originally Posted by <strong>BrinNutz</strong>
</div>
<div style="font-style:italic">what stepping did you get man?<br />
<br />
It's all about the stepping of the 165 man...If you got a CCBWE, you'll probably only make it to 2.4-2.6, if it's a CCBBE or CCB1E, you have a very good shot at 3.0ghz</div>
</td>
</tr>
</table>
</div>I thought all Opty steppings guaranteed at least a 2.7 OC (seeing as how everybody praises these chips)? If there is a possibility of getting stuck at 2.5 I may as well get a X2 4400. @dotcomthese; do show us your results please. Planning on getting one myself.
Discussion Starter #5
well there's my first starting point...but when I checked my cpu the stepping was ccbbe0617 not 0610....sooo dunno....most places I checked show that as a good stepping..
Retired
<div>Originally Posted by <strong>dotcomthese</strong></div>
<div style="font-style:italic;">well there's my first starting point...but when I checked my cpu the stepping was ccbbe0617 not 0610....sooo dunno....most places I checked show that as a good stepping..</div>
</td>
</tr></table></div>
Good stepping, I got mine up to 3012 mhz (benchmark stable, not prime stable), check out the cpuz in my signature. Its a good stepping, not as good a ccbbe0610, and if you paid extra expecting that stepping, i might be a little upset, but still its a nice stepping, expect 2.7 on stock volts, 2.8 with a little bump on vcore, and 3.0 with 1.56 volts (water would be suggested).
if you do not mind me asking who did you get it from on ebay just got mine too, and that is the stepping that it said I was getting
Discussion Starter #8
well the egg has them for 159.99 and luck of the draw so what i've read so far on google the extra 13.00 for a good stepping is prolly worth it. gonna go kinda slow because I'm new to the board and cpu so.keep up the posts.
Discussion Starter #9
<div>Originally Posted by <strong>jacobdrw</strong></div>
<div style="font-style:italic;">if you do not mind me asking who did you get it from on ebay just got mine too, and that is the stepping that it said I was getting</div>
</td>
</tr></table></div>
Uhhmmm some guy from north carolina...<br><br>
~~edit~~ when did AMD switch to the copper heat pipe sink and fan???
<div>Originally Posted by <strong>Melcar</strong></div>
<div style="font-style:italic;">I thought all Opty steppings guaranteed at least a 2.7 OC (seeing as how everybody praises these chips)? If there is a possibility of getting stuck at 2.5 I may as well get a X2 4400. @dotcomthese; do show us your results please. Planning on getting one myself.</div>
</td>
</tr></table></div>
Heck no man...There are the CCBWE steppings, which have pretty crappy memory controllers...So, the only good CCBWE steppings came from one certain batch date, 0546 maybe? And then, only some of them were good oc'ers..<br><br><br>
Check this thread out over at xtremesystems for more info (This ones for you CompGeek) :<br><a href="http://www.xtremesystems.org/forums/showthread.php?t=96900" target="_blank">http://www.xtremesystems.org/forums/...ad.php?t=96900</a>
Discussion Starter #11
well i'm @ 2.48 and closing in on more...running ram @ 266 with loose timings til later [email protected] 1t....<br>
~~edit~~ 2.548 @ 3-3-3-7 1t done for the evening.....but guess it's a good start
Discussion Starter #12
<img alt="" class="inlineimg" src="/images/smilies/thumb.gif" style="border:0px solid;" title="Thumb"> latest cpuz, no hickups yet, haven't had to ask any a8n questions...YET...that's a plus..so just slowly cruisin' along<img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin">
I'd lower your VCore and see how far that gets you before raising it (unless you've already done that). You may need to loosen your memory timings. <br />
<br />
I'm sitting at 2.8GHZ @ 1.33 vcore, I can probably do 2.85 GHZ at stock vcore.
Reactions: dotcomthese
Discussion Starter #14
well so far so good and no blue screens yet..thanks for the tip on the voltage forgot the opty runs well at low vcore....Only have my ram volt increasd right now, haven't touched the north bridge so it's still at 1.5...But have come across a question..there is a setting on the ht voltage should this be left @stock...if so why for future reference and if increase is needed later and same reference question...Thanks all
The Memory controler voltage like the chipset voltage...<br />
up only as necessary when you find instability in an effort to determine where the weakness/instability is.<br />
<br />
Nice OCing <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
Discussion Starter #16
thanks duke your information is always top notch and to the point<img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />
Why x9 multy?
165 Optys default is 9x
OK.Thank's,That mean is doing good.Stay on it.
Discussion Starter #20
uhmmm the board set it @that auto i didn't even think to check the multi. But I believe the multi is 9 for the operton<br />
~~edit~~ answered
1 - 20 of 59 Posts
