What do your temps look like now, and do you use HT?
Edit: I have been thinking about switching to a water setup, but some people one here make it seem a bit too risky. I just want to hit about 4.2 with HT and stay under maybe 60-65.
you should of gotten at least a 240 rad man. post your temps once you have it all hooked up. good luck
I am already running a black ice extreme 240 with scythe 110cfm fans in a push pull this is just an addition
I am also adding 25 mm shrouds to the 240 as well as a 50mm shroud to the xspc. Right now I am running at 3.8 with ht on for daily use. While running prime95 it usually stays between 52-57 depending on the ambient.
1 - 6 of 6 Posts
