New PC build
545 Views 14 Replies 11 Participants Last post by  mr. biggums
I'm planning to a gaming PC for around $500. I'm stuck, however, on the motherboard and graphics card. This is what I'm looking at currently:
ASRock P43 Mobo
http://www.newegg.com/Product/Produc...82E16813157130
Sony Optiarc DVD Burner
http://www.newegg.com/Product/Produc...82E16827118012
Antec 300 Case
http://www.newegg.com/Product/Produc...82E16811129042
Seagate 250gb HD
http://www.newegg.com/Product/Produc...82E16822148261
HIS IceQ 4670
http://www.newegg.com/Product/Produc...82E16814161249
NeoPower 650W
http://www.newegg.com/Product/Produc...82E16817371011
Tuniq TX-2 Thermal Compound
http://www.newegg.com/Product/Produc...82E16835154003
Patriot Extreme Performance 2x2gb
http://www.newegg.com/Product/Produc...82E16820220227
Finally, E5200
http://www.newegg.com/Product/Produc...82E16819116072
Decided on everything! I chose the ASRock because it supports DDR3 and I like to future proof. Same thing goes for the power supply. I chose the 4670 because my monitor can only play on lower resolutions. I'll have it up and running (HOPEFULLY) in a few weeks.
Edit: WRONG SECTION. Damn.
1 - 15 of 15 Posts
Are the earthwatts comparable to Corsair's offerings?
Originally Posted by kazakia View Post
Cut down to a 8800GT or 9800GT for $100 then get this
http://www.newegg.com/Product/Produc...82E16817139008
perfect for ur rig
Why cut down to 400w. The one hes getting is more watts
Because before today i have never even heard of HEC and the rvies arent exactly that good. IT looks like those cheap dodgy PSUs that you tend to avoid.
Although it may have a higher wattage it would be unstable and might lead to hardware failure whereas if you buy the corsair which has 30A on the 12v rail you are guaranteed a safe, sturdy PSu to rely on. 400w is enough for that rig especially if its corsair.
Yea the earthwatts are ok aswell but obviously not as good as Corsair. Your choice.
What are your opinions on Recertified/Open Box video cards? There's a recert EVGA 8800GT for 109, and an Openbox ASUS one for 99.
Then Antec case has a very nice combo with the Antec Earthwatts 500w for like $70 I think.
The 4830 is a fine card, and I think you should keep it. P43 is fine, unless you need the overclocking of the P45
This looks really appealing too:
http://www.newegg.com/Product/Produc...82E16814127381
A good cooler and OC edition.
Agree with Wookie, go with the Antec 300 and EW500 combo at $69, still cheaper than separate case and HEC psu.
thats what most people do
ew500 + antec 300 = better for the money
. im proud of a lot of people getting the antec 300
previous build for someone else:
E5200 CPU - http://www.newegg.com/Product/Produc...82E16819116072 $84
Biostar TP43 Mobo - http://www.newegg.com/Product/Produc...82E16813138122 $80
XFX 9800GT GPU /w free CoD-4 - http://www.newegg.com/Product/Produc...82E16814150316 $110
Antec 300 Case & PSU combo - $70
4GB Crosair Ram - http://www.newegg.com/Product/Produc...82E16820145184 $40
DVD burner - http://www.newegg.com/Product/Produc...82E16827118012 $24
250GB HD - http://www.newegg.com/Product/Produc...82E16822148261 $50
Total ~ $458
leaves room to buy a decent CPU cooler.
Total ~ $458
i second this
but id go with a decent P45 or gigabyte P43-DS3L at the very least
The Antec 300 is currently free shipping at Newegg AND comes with a POS PSU.
its looks good the p43 is a good board has some overclocking potential but not as much as p45 and up, but it will do for your rig. The 4830 is an ok vid card but I would get the 4850 for only $20 more and it has a higher core and memory clock not to mention higher stream processors.
its a bit over your budget but certain things can be switched out too lower the price for ya
or intel if you prefer
those pics are a bit old so u can get the antec case/psu for 70 so it will drop both the prices down by roughly 20$
i'll also attempt at cheaper prices aswell if you prefer
1 - 15 of 15 Posts
