1 - 2 of 2 Posts
This is my first build with non cheep/out dated parts. So I wanted to do things right, and try my hand in new things.I have been able to OC it to 3.6 already. It is stable and runs betwen 34c-36c and the most I have seen it hit is 41c under load so far.
So I am sure I could squeeze some more out of it.
I am unsure of how to do this. I have read everything I could, and I think its just slipping though my head on how to do this.
I put the Multiplier x18.0 and had lowered the voltage some and it is very stable. If I change the Multiplier any higher, it blue screens. Same with the value for the Multiplier, also with any combo with the voltage. I have seen in others posts their HT link is around 2,000. I have no idea where in the BIOS to change that if that will make a difference.
Any ideas? I also know I can change the RAM settings some, but I think that is also me grasping for straws and drawing a blank.
I'll post some pictures too! Thanks in advance! I enjoy reading everything so far. I can't tell you how much I have learned already. I'm just ready for more.
Efficiencycionado
set your ram timings manually. and it should let you push it further. and when you want to push further 3.8, lower the ram speed by a level, time them manually and add more voltages to your cpu, ram and northbridge. then it's about time you start increasing the bus.
1 - 2 of 2 Posts
