new power rig!!
646 4
Ok thinking of making my new rig soon within the next few weeks
just need some help with some parts:
mobo:asus a8n 32 dunno which model?
dfi lanparty nf4 sli-dr expert? which dfi is better?
any others?
processor: thinking of the athlon 64bit x2 4400 but i saw the opty 170 but its san diego core? is that any good?
http://www.overclockers.co.uk/acatalog/AMD_64_X2.html £335
http://www.overclockers.co.uk/acatal...Athlon_MP.html £318
graphics: thinking to go nvidia?
wana get a 7800 but for about under £250 since the 2 mobo are sli
ram: at least 1gb of overclockabl ram
GeIL 1GB (2x512MB) PC4400 Ultra Platinum CAS3 £126
http://www.overclockers.co.uk/acatal...nnel_Kits.html
thanks
1 - 5 of 5 Posts
· Premium Member
Either MB is very good! The Asus is a bit more user friendly where as the DFI is more demanding and has more BIOS options!
On the CPUs...
The alleged core is irrelevant!
Both choices are excelent... get which ever you can thats cheeper.
On the RAM ... if you can squeeze the extra money, consider 2x1G vs 2x512s!
yeah both mb seems very good but i want a more future proof mb but there is not such thing in the computing world is there...
in overclocking terms i hear the dfi is greater as it has many OC options so i can squeeze out more performance, when it starts to lag.
but i also hear that the asus is not far behind the dfi and in some performacnce it beats the dfi.
but i ve read in the forum, for a dual core, that the asus limits my vcore to only 1.55v, as im thinking of getting the system to OC as much as poss. with water cooling im sure i can go over to a higher vcore and get better OC results.
or is there not much difference?
btw if i were to get it watercooled any suggestion on a set up? under £150 if possible
thanks
ok i have decideed on the dfi lanparty sli dr expert board
i know it needs a 8 pin connector and a 24 pin connector
can any one recommend a good PSU but i dont really wanna spend over £100
ive seen the enermax noisetaker 600W for about £93
or maybe the seasonic s12 600
anyone find a cheaper realiable one
and will the two above fit my dfi expert?
pakapak I just built one of these machines. DFI expert board 2x512 Crucial Ballstix Tracer DDR500 2.5-4-4-8 @ 2.8v AMD Opty 170 overclocked to 2.5GHz stock volts personly for the power supply I would get Antec Truepower 2.0 550W that is what I have. But if you plan on DX10 card or SLi then get OCZ GameXtreme 600W or 700W. Those three are on the DFI recommended list.
1 - 5 of 5 Posts
