new power supply
391 Views 6 Replies 5 Participants Last post by  reezin14
if i get the corsair 750tx , can i overclock higher for encrease in stability or is just the same thing
1 - 7 of 7 Posts
You will not be able to increase your overclock with a new power supply.
I would recommend an Antec TruePower New 750W over the Corsair TX 750, also.
What is your current power supply?
Edit: I don't know how good or bad that PSU is, but getting the TX750W probably won't make any bit of difference except for one thing: you will have a much, much, much better PSU (I think?)... maybe. I don't know. lol
You can increase stability though
You can increase the general stability of your rig and increase the lifetime of your components with a better power supply, yes.
I'd get a new PSU right away, to be honest. I wouldn't want your current PSU to crap out on you and take lots of hardware with it.
You'll probably be more stable with your oc's,and I believe that either of the psu's suggested would be better than the one you have currently.I personally love the corsair & it's a bit cheaper than the Antec.
1 - 7 of 7 Posts
