I need a new power switch for my computer. I was looking at the VL System Touch One but I was wondering are there any other options? I don't need any fancy features, just something that turns my computer on and off.
Originally Posted by Bindusar That one looks like it isn't SPST...maybe DPST. Would that one work out? Does it have to be momentary? I am thinking it doesn't have to be in order to work...just needs the interuption, right? To use that one you would have the two leads that go to the mobo set up with one going to the center terminal and the other to one of the others...I think. Use a multitester to check the continuity. |
Originally Posted by Bindusar True, simple trial and error will work as well since either it turns on or nothing happens, but since I have a couple testers laying around I find it easier to just check the switch before hand. If you have the right clips for the terminals on the switch it should be easy to change from config to config. I would just say make sure the rig is unplugged before changing them if the first one doesn't work. |
Originally Posted by Burn If I had the choice, I'd get one of those cool military-grade SPST switches...You know, with the guard on it... |
Originally Posted by laboitenoire If you want some cool switches, take a look at the Bulgin Vandal series. Those are cool. Momentary push-button style, built in LED for power or HDD indication. Plus, they're certified for use in hostile environments (in case you get in a lockdown situation where you need to arm some uber-cool weapons system while gunmen are having a firefight in the room). |
