New PWM fans from Noctua
In late 2011 Noctua refreshed its entire line of fans by putting out PWM versions. They also introduced a new fan. Let's look at two of the updated fans and the new one.
Here are the NF-P14 PWM and the NF-P12 PWM:
Noctua engineers took some years to figure out how to make PWM PCB's so that they operate quietly. Did they succeed? We'll see.
Now let's look at the new fan, the NF-F12 PWM:
Those vanes are called stators. When a fan's output is blown through properly designed stators, it focuses its airflow and it increases its static pressure. Noctua says not to expect more airflow from this fan. We shouldn't see or any better cooling on their coolers. That's because the NF-F12 PWM is designed to push more air through constricted settings, like radiators.
Currently the NF-P12 PWM and the NF-F12 PWM are available retail. The NF-P14 PWM is not. You can't buy it separately. It only comes with Noctua heatsinks.
So let's look at the P12 PWM and its box:
It has nine blades, and it comes with accessories, of course:
From the left:
A PWM Y-cable. Both branches have gnd, 12v and PWM control lines. Only one has an RPM reporting line, to avoid confusing the motherboard with more than one RPM signal.
A 30cm (one foot) extension cable. Since the fan has only a 20cm long (eight inches) cable, this allows a longer reach if you need it.
Four "Vibration Compensators." They come with all Noctua fans. You are supposed to use these to fasten the fan to a case with these. Let me know if you can make these work. I want to know how.
There is a packet of four standard fan screws (not shown).
In front of the fan is the Low Noise Adapter (L.N.A.), part no. NA-RC6. It will reduce the fan from 1300 rpm to 900 rpm -- and still let the PWM signal control fanspeed.
And Noctua provides a product page for the NF-P12.
Here is the NF-F12 again:
The corner cushions are made of silicone rubber to cut down vibrations. The diagram on the inside cover of the box illustrates the advanced technology features of this fan: the stepped inlet design, the inner surface dimples, the improved SSO bearing. It explains that the stators are not evenly spaced around the fan's circumference. On the next page there is a chart that shows how moving the 11 stators just a little bit to a slightly irregular spacing attenuates some noise spikes. I will predict that we should hear less of a tone from these fans.
NF- F12 Product Page.
And these are the accessories:
30cm PWM extension cable.
Screws.
Low Noise Adaptor. This one is an NA-RC8. It reduces the fan from 1500 rpm to 1200 rpm. I compared the NA-RC8 to the NA-RC6 from the P12. On the D14 the RC8 dropped my P14 to 900 rpm. The RC6 dropped it to 700 rpm. So the NA-RC8 has a stronger resistor than the NA-RC6.
The superb Noctua PWM Y-cable. Note that all the cables are beautifully sleeved.
Four Vibration-Compensators.
Fan Testing:
12v: I plugged each fan into my PSU's 12v Volt line to get the max speed. With the PWM line unplugged you get the maximum rpm a fan will do. You should get 100% fanspeed, but 100% on your motherboard may not reach the fan's maximum speed.
Gnd: Poked a grounded line into each fan's PWM channel. This emulates 0% PWM duty. In the case of the Noctuas, all three fans stopped. This is unusual PWM fan behavior. Most go to some minimum speed when their PWM rate is zero. And from there the fanspeed will increase with PWM duty; but the increase is often, even usually not linear. We'll see if the Noctua fans have a linear PWM duty vs. RPM speed curve.
The fans then were tested on the Zalman PWM Mate, which is a PWM controller. The PWM Mate generates an approximate 25%, 50%, 75% and 100% PWM duty to each fan. Measured fanspeed with the motherboard utility. Measured the sound pressure level with an SPL meter from 10cm directly in front of the fan. Subtract 20 dB and you have the equivalent sound pressure level of what you would hear one meter away.
Here are the results:
From the left:
Screws.
Fan Testing:
Noctua fans | PWM duty | Noctua |
