1 - 20 of 42 Posts
***NEW QUESTION***
will this and this fit internally into this
I will be watercooling and with a 240 rad and was wondering which one would be better
my w/c parts list
what fans would you recommend
Discussion Starter #5
yes
but I can live noise
Originally Posted by gdawg33 View Post
yes
then delta fans or yate loons . but i prefer coolermaster case imo
Discussion Starter #8
Originally Posted by KoolGuy View Post
*Sighs* Not much i can do there im all performance.
One delta 252cfm can out perform a case full of silent fans BTW..
I said I can live with it as I have my headphones on most of the time
Discussion Starter #10
It already comes with fans?
What do you want to do negative pressure or positive pressure?
what do you mean?
PC Evangelist
HAF 922, PC-K62 cant fit a 240 ran inside or the back.
Discussion Starter #12
yes I know the haf can as I have built a computer with one and they have screws at the top for two 120mm fans
what do you mean?
A positive pressure case means that there is more pressure inside the out side.
A negative means there is less pressure inside the outside. (Which scientifically this isnt true but its the consept)
basically do you want you PC to have more power psuhing air in then pushing air out or more power pushing air out then in.
Discussion Starter #14
I want more air coming in than out
Discussion Starter #15
I think I will go with the K-62 as long as there are screws on the top for 2 120mm fans
Discussion Starter #17
for the w/c loop its $220
PC Evangelist
Mine does not have screws for 120mm.
Discussion Starter #19
going by your sig rig you have the Haf-X which has a different fan setup
1 - 20 of 42 Posts
