I just got 2 sticks of Patriot 1GB DDR400 ram when I install 1 stick everything is fine but if I put in two it posts but then says detecting array and just sits there then restarts and does the same thing.
I have tried every possible combo 1 and 3, 2 and 3, 1 and 2 and same thing also when I have both in and let the DFI board select my Multiplyer it runs fine but only runs at 860MHz
Well I was hoping someone would jump in there and help ...Well try just stock settings.200 fsb and 1:1 ratio on the ram...I believe the 3500 is a x11 multi...See if it boots then you can tweak it from there...Wish I could help more but that is probably where I would start to check a problem..
Well are you saying it locks at detecting your sata?? Check and see if you got the right sata port enabled...Does it boot all the way to windows wih one stick??
with 1 stick at 200FSB x 11 Multi everything works fine runs games windows everything. put a second stick in it post the says detecting array I have no raid or anything just 1 SATA HD but if I put it to 200FSB x 4 Multi everything works fine run windows games but only at 800MHz.
Are the RAM setting @ the MB's default.. ie; did you clear the CMOS before installing?
Did you enter the RAM's default timings?
Have you tried upping the vdimm any?
Have you tried upping the LDT voltage?
That brand isn't known for having any issues with DFI MB as far as I can recall.
well before I upgraded my Ram I was running at 260 x 10 now im just at 210 x 11 and not really tryin to push it just saving money to do a complete upgrade.
