1 - 16 of 16 Posts
Hey guys!
So I already have a case (HAF-X) Power Supply (850 watt Corsair modular) Cooler etc. All the parts I neeed are below:
http://pcpartpicker.com/p/jTpmBm
Intel Core i7-5820K 3.3GHz 6-Core Processor
$373.95 $373.95 SuperBiiz
MSI X99S SLI Plus ATX LGA2011-3 Motherboard
$194.99 FREE $194.99 Newegg
G.Skill Ripjaws 4 series 16GB (4 x 4GB) DDR4-2666 Memory
$249.99 FREE $249.99 Newegg
Crucial M500 480GB 2.5" Solid State Drive
$203.78 FREE $203.78 NCIX US
EVGA GeForce GTX 970 4GB Superclocked ACX 2.0 Video Card
$349.99 -$10.00 FREE $339.99 Newegg
I will get the SSD/CPU/Mobo from Microcenter ( I have one near me) so the cost will be a bit cheaper.
Any thoughts on what I may want to change? My budget is around $1k-$1200 or so.
Thanks!
pass the lortabs
It looks pretty healthy at first glance. Is this going to be a primarily gaming computer and if so, at what resolution?
I'd shoot for a MX100 or Samsung 850 ssd
Mostly gaming. Eventually I would like to move to 4K but that will not be till my current monitor dies. I have a BenQ T24IW.
Crucial seemed to have great bang for the buck, especially @ $169 in Microcenter for 480 GB. Any reasons why Crucial would be a bad choice?
Thanks!
waifu for lifu
Originally Posted by keikei View Post
If you're moving to 4k, may want to move up a little to the 980 if feasible. You'll need as much gpu power as possible to run at that res. http://us.hardware.info/reviews/5623/3/nvidia-geforce-gtx-980-sli--3-way-sli--4-way-sli-review-benchmarks-battlefield-4
I'm not 100% when I will move to 4K. I am thinking it will be 3-4 years before I do that. I will most likely start at 1920 x 1200 until this monitor dies, then I may go 27" at 2560 x 1440. I think 4K will take a while before monitors become reasonably affordable
To The Game
Man, I don't think I've ever had a monitor die on me. I've retired them, but die, if it makes it past that first 3 - 6 months then it's likely going to last a long, long time. Hell, not too long ago I tossed out a old Dell 17" 1024x768 that I had for something like 10 years to free up some space.
*2560x1440 is more res then 4k. It would also be more expensive then buying a single 4k monitor.
Talking about triple screen. Not sure what happened there.
pass the lortabs
You could go this way as well:
PCPartPicker part list / Price breakdown by merchant
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($199.99 @ Micro Center)
Motherboard: ASRock Fatal1ty Z97X Killer ATX LGA1150 Motherboard ($124.99 @ Micro Center)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-2133 Memory ($76.98 @ OutletPC)
Storage: Crucial MX100 512GB 2.5" Solid State Drive ($196.99 @ SuperBiiz)
Video Card: PowerColor Radeon R9 290 4GB PCS+ Video Card (2-Way CrossFire) ($269.99 @ Newegg)
Total: $1138.93
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2015-01-16 17:17 EST-0500
Thanks guys! I wanted to go DDR4 since I will be keeping this rig for at least 5 years. How much of a performance boost will I see with a 9+0 and 5820k?
Discussion Starter · #11 ·
just got a samsung 850evo 500gb. I know i have been talking about the i7-5820k...but wanted to hear thoughts on an amd equivalent. Thanks!
There is no AMD equivalent to the 5820
I'd suggest a 8310/8320e for $110 and overclock on budget. For pure power go intel
Not New to Overclock.net
2011-v3 is currently a very viable socket in the long run as the currently available motherboards should support newer CPUs with only a BIOS update.
DDR4 can also be found at the current DDR3 prices, which is good enough for a transition.
And yes, there is no AMD alternative to this setup as of now.
Have you had your morning coffee?
He is talking about one 16:9 2560x1440 monitor, which is about 45% of the resolution of a 4k display.
How is 2560x1440 higher rez than 4k (3840x2160)?
To The Game
I was talking about 3 x 2560x1440 (triple screen).
Not sure what happened there. Might of been a case of getting posts mixed up, which happens sometimes if I have a few I'm involved in.
Total: $1138.93
this guy knows how to put computers together.
he has 2 r9 290s listed ~ $520 if you wanted to spend the extra $$ maybe go 1x r9 295 x2 ~ $650
1 - 16 of 16 Posts
