Hey guys, building a new sg06 build in the next few days, and im deciding whether or not to go haswell. Im probably planning on going with an i7 4770 (or 3770 if i do ivy bridge) because this will also be my main PC and im going to be studying engineering, so I think I should spend the extra bit of cash to get the hyper-threading to help out with CAD and whatnot. The problem is the temperatures ive seen the haswell chips getting up to, 90 on full load on stock cooler, plus it being inside a tiny sg06 with a full size video card is kind of worrisome. Should i not be worrying about it, or is there no advantage to going haswell over ivy?
Also,im planning on buying a gtx 770 in a month or two, going to use a gtx 660 i have for now, and was wondering if any knows if the MSI GAMING Gtx 770 fits in an sg06? The size is 260mm, and the sg05/sg06 have a maximum of 262mm, should it technically should fit. Its also the only 770, as far as i know, that would fit inside the sg06.
Thanks in advance
Thanks in advance
